Perform this procedure to display configuration information for Endpoint Tracking.
Perform this procedure to display global, interface and binding information for Endpoint Tracking.
The following example displays all of the Endpoint Tracking configuration information for a switch.
Switch:1>show endpoint-tracking ======================================================================================= Endpoint Tracking Configuration ======================================================================================= endpoint tracking status : ENABLED auto-isid-offset value : 15990000 auto-isid-offset enabled : ENABLED visibility-mode status : ENABLED
Switch:1>show endpoint-tracking interfaces ========================================================================================== Endpoint Tracking Interfaces ========================================================================================== PORT NUM INDEX STATUS ------------------------------------------------------------------------------------------ 1/1 192 Enabled 1/10 201 Enabled MLT-2 6145 Enabled MLT-5 6148 Disabled -------------------------------------------------------------------------------- 4 out of 4 Total Num of Endpoint Tracking interfaces displayed --------------------------------------------------------------------------------
Switch:1>show endpoint-tracking bindings summary ================================================================================================================== Endpoint Tracking Bindings ================================================================================================================== PORT/MLT INDEX TOTAL ACCEPTED REJECTED PENDING TIMEOUT SERVER-UNREACHABLE ------------------------------------------------------------------------------------------------------------------ 1/10 201 5 5 0 0 0 0
Switch:1>show endpoint-tracking bindings ================================================================================================================== Endpoint Tracking Bindings ================================================================================================================== PORT/MLT INDEX MAC STATUS VLAN ID ISID SOURCE TIMEOUT TIME REMAINING ------------------------------------------------------------------------------------------------------------------ 1/10 201 00:00:00:00:1b:01 accept 27 15990027 autoconfig 0 day(s), 00:01:40 0 day(s), 00:00:00 1/10 201 00:00:00:00:1b:02 accept 27 15990027 autoconfig 0 day(s), 00:01:40 0 day(s), 00:00:00 1/10 201 00:00:00:00:1b:03 accept 27 15990027 autoconfig 0 day(s), 00:01:40 0 day(s), 00:00:00 1/10 201 00:00:00:00:1b:04 accept 27 15990027 autoconfig 0 day(s), 00:01:40 0 day(s), 00:00:00 1/10 201 00:00:00:00:1b:05 accept 27 15990027 autoconfig 0 day(s), 00:01:40 0 day(s), 00:00:00 5 out of 5 Total Num of Endpoint Tracking bindings displayed.
The following table defines parameters for the show endpoint-tracking bindings command.
Variable |
Value |
gigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
MLT <1-512> |
Specifies the MLT ID. |
summary |
Provides a summary of the total number and status of bindings for all interfaces. |
